MS425 1G backward compatibility
msosa
   Hello! I just want to know if the SFP module in Catalyst family SFP-10G-LR-S is compatible with he Meraki family devices that supports 10Gbps SFP+ modules??
   thank you in advance!
This is the list of all officially supported modules.
https://meraki.cisco.com/lib/pdf/meraki_datasheet_sfp.pdf
SFP-10G-LR-S is hihly likely to work, but is not officially supported.  If you run into an issue and support think it may be related to the SFP+ being used they may ask you to replace it with a supported module before continuing to help.
1 Reply 1
