MS410-32 PBR / VRF
KarstenA
MS410-32 PBR / VRF
Good Evening
My challenge is that I have 2 L3 MPLS, one must be the default route for data and voice vlan + meraki management vlan and the other must be the default route for guest wireless vlan. I know that MS410 does not support PBR or VRF. Any tips how i can accomplish that, whitout truking it to an another L3 device / L3 switch with a seperate routing instanse
Make the second L3 MPLS circuit the default gateway for the guest traffic, and keep the guest traffic and the L3 MPLS all in one L2 VLAN on the switch.
2 REPLIES 2
Thanks for your answer.
Yes i did thought of that but I was hoping not to change anything at the ISP as i want to manage the routing. But i think its going to be the solution.
Thanks again.
