MS390 stacking
Typhos
MS390 stacking
Is it possible to add a second ms390 without powering off the first unit ?
merakichamp
@Typhos
very possible remember MS390 is one meraki switch that has been designed with almost equal features
like cisco catalyst switches especially cat 9k series you can learn more about that and one of the features is
hot swappable power which will allow you to add or remove without shutting down
1 Reply 1
merakichamp
@Typhos
