MS390 power usage not showing correctly in dashboard
Mateus0801
When I click on the power tab to see the Power usage on the switch the page is blank. Also, on the ports page, several of these ports are providing power to cameras and the POE usage is not showing up. All switches are on firmware version MS 12.28.  This is only happening on my MS390 switches.  MS MS225 switches are running the same firmware version and the pages are displaying properly.
Ports tabPorts tabPower tabPower tab
Bruce
Check with support, but I think you’ll find this is one of the ‘known bugs’ on the MS390 switches. A lot of the power issues were corrected on the MS14 code for the MS390, but be sure to read the release notes to make sure you don’t hit other issues (e.g. stack size) if you decide to upgrade.
Bruce
Mateus0801
Thanks, Bruce.  I will look into that.  I opened a support ticket yesterday.  I haven't heard back from them yet.
Mateus0801
You hit it on the head, Bruce.  Firmware version 14.7 adds:
  • MS390 now displays Power Supply State and PoE power status/usage.  At the time of this post, 14.8 is the newest beta version.
