@Marcel wrote:
I'm a bit jeaous as don't have one yet, but it should go in this order:
Gig->mGig - 10G -40G
So for your MS355-48X2 it should be
1-24 1G
25-48 mGig
49-52 10G
53-54 40G
Awesome, that is also my suspicion @Marcel. Thank you, and @PhilipDAth aswell. 🙂
It wasn't to much the switch specs, but more, which ports are GbE and which are MGig. Then I can make sure the technician onsite cables things correctly. 🙂
LinkedIn :::
https://blog.rhbirkelund.dk/Like what you see? - Give a Kudo ## Did it answer your question? - Mark it as a Solution
🙂All code examples are provided as is. Responsibility for Code execution lies solely your own.
