MS350-24X + MS225-LP
inrsys_lf
Hello I have a fairly small setup for one of our sites. 1 data closet will be hosting the MS350-24x that connects via 10G SFP+ to a 3rd party firewall. Two MS225s will be in an IDF about 20 meters from the data closet. The question is: can I interconnect the MS350-24x using the mGig ports to the MS225-LP 10G SFP+ ports using 10G-BASE-T modules to achieve "10G"?
1 Reply 1
DarrenOC
Hi @inrsys_lf , you’re well within the 100m limitation for copper so you’ll be fine.  Ensure the cabling is Cat6a.
