MS250 NTP config
nguzman
MS250 NTP config
How can I configure or change the NTP server that the meraki switches is using?
Nash
NTP is handled by the Meraki Cloud. You cannot manually configure NTP on Meraki devices nor use them as time servers for other devices on your network.
5 Replies 5
Nash
nguzman
Thank you.
jdsilva
You can't. Time is set via the Dashboard. All you can do is change the timezone.
nguzman
Thank you
Sc00baSteve
Just browsing
NTP can be set up in the DHCP Pool as an option (Code 42) on the MX device. Especially if you have non-meraki downstream switches
