The first thing to note is OM2 is multi-mode fibre. The next thing to note is OM2 is quite old now, and only has a range of 82m when used with 10Gbe.
You will want to use MA-SFP-10GB-SR (which supports multimode).
If you can, try and use OM4 (which has a range of up to 400m).
