MS225-48FP PoE HIK Camera
Ksyl
I have a problem with my MS225.
When I plug a PoE camera (HIK Vision) on port 4 all is fine.
When I plug the same camera on port 5, no link go up.
PoE is enable on both ports obvioussly.
The problem is larger than that, i have to plug 6 cameras and only one of them wakes up. Every ports have the same configuration.
When I change the cameras randomly on the same 6 ports, only the camera plugged on port 4 wakes up.
I Don't really know what to do.
Can you help me please ?
Regards,
Amaury
BrechtSchamp
Have you tried with another MS225?
Have you tried other PoE devices on the ports that don't work with the camera?
Anything in the event log?  Network Wide > Event Log
What are the specs for the camera? What exact model is it?
Thank you for your help !
- Yes I have tried on another MS225 and it works perfectly.
- Yes i have tried with another PoE device, a Yealink IP Phone (T42S) and it works too
- There is nothing in the event log except "port status"
- Here are the specs : https://www.hikvision.com/fr/Product/Detail/149574905159149/307639277371446
My first think is there is a problem with the first MS225 but, the MS is a new one through guarantee process.
BrechtSchamp
If everything works fine on another MS225 and also on one of the other ports on the switch, it looks like a hardware issue with the switch. Even if it's one that came "new" through warranty.
If I were you, I'd get it replaced again through support.
The camera datasheet states it's using 802.3at, that's PoE, so it should work fine.
Edit: Assuming that the config on the working MS225 is identical and that it's running the same software.
Thanks again, i will do that.
And yes, both MS are running the same software and all ports have the same configuration.
