MS210 SFP Port LED Colors
MMatt
Just browsing
Hi
I'm configuring an MS210. I have a Meraki SFP and single mode fibre cable plugged into the an SFP port on the switch. The LED for the port is amber/orange. What does this mean? On the MS225 I found it means the link is connected at 1Gbit is this the same for the MS210?
AjitKumar
Hi
I believe the port speed is negotiated and is working at lower speed than the desired.
For more information please refer the following Url
https://documentation.meraki.com/MS/Installation_Guides/MS210_Series_Installation_Guide#Ports_and_St...
Regards,
Ajit
AjitsNW@gmail.com
www.ajit.network
Fibre modules don't support speed negotiation.
If you hover your mouse over it in the dashboard what does it say?
