MS1208-LP
AdamVH1
MS1208-LP
I have a client that requires compact SFP support on a project.   Does the Meraki line support cSFP ?
5 Replies 5
Adam
Interesting I had not heard of compact sfp before.  I did some reading and I don't see any documented support but the sfp technology is somewhat standardized.  Had you tried it in a Meraki switch yet or are you just doing discovery?
AdamVH1
doing discovery at this point in time.   I've switched companies recently and no longer have access to Meraki gear.  I am trying to get this company into Meraki .. but .. baby steps.
The client is a small FTTP provider.  They are using Calix gear for that.  Thats where i learned about the cSFP.
jdsilva
Neato. I've also never heard of these. Very cool.
We use BiDi's in Meraki gear quite a bit, and those work just fine. It's possible that cSFP's will work too... I wish I had one here to test with.
Following this to see what the outcome is.
AdamVH1
Thank you.  I wasn't sure if a BiDi would work either.  I just never used them, until now.
I've never heard of them either - but I think they are unlikely to be supported.  Basically that are a 2Gbe port - and I can't see many SFP ports being able to use them.
