MS120-8FP Query
Takis_Samanis
MS120-8FP Query
Hello Experts,
I see in the datasheet that the switch supports LACP. Can the feature work in both uplinks and downlinks?
My problem is that if link aggregation only works on the downlinks we will have a bottleneck on the unbundled uplinks.
Does this switch support multigig? To be honest I've not seen it anywhere in the documentation
Thanks in advance
Ryan_Miles
LACP is supported on any of the switch ports. And, no the MS1xx series doesn't have mgig. To get mgig you need to be in the 3xx series.
Ryan_Miles
BlakeRichardson
@Takis_Samanis The 1xx series are entry level switches so not all features are available on them. The 2xx series has a few more features and as mentioned the 3xx series have multigig ports.
Takis_Samanis
Thanks guys 😀
