I have one quantity MS120-8FP-HW unit, and it difference from other MS Meraki produces, it have not Management port, so that i don't know which port can be connect with internet, which port can be connect with login local.
Additionally, It also was same local login method with "my.meraki.com" or "switch.my.meraki.com".
Solved! Go to Solution.
Check my answer here for the procedure from experience:
https://community.meraki.com/t5/Switching/Factory-reset-of-a-MS120-8P/m-p/43788/highlight/true#M3674
You can use any LAN port on most devices, out of interest why do you need a local connection, we have never used the local connection on our MSs?
Yes. And in dashboard, the port that the switch is using to reach the internet will show up with a little upwards arrow. See port 1 here:
Hi Brecht,
I have question for you, how to use local status page to assign it another IP ?
