We're migrating to the Cisco Community on March 29. The Meraki Community will enter read-only mode starting on March 27.
Hi all, can anyone let me know if i use fibre to copper sfp's will i be able to use the SFP ports for end devices i'e 2 additional pc's , effectively have 10 usable copper ports
Solved! Go to solution.
Yes, it works without any problems on several MS120-8.
Same here, we use Cisco GLC-T modules and they have been 100% reliable for years.
I usually use the SFPs from FS; I use the original SFPs only if the Customer doesn't want third-party components.
Thanks KarstenI
Going sideways - do you know about the 12 port switches?
https://meraki.cisco.com/product/switches/access-switches/ms130-12x/
12 is the new 8 …
And then they will want 14 copper Ethernet ports.
