- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
MS100 and MS425 core switch
Hi, quick query on VLANS within a Hyper V deployment
Want to set up 4-5 vms with different VLANs
Budget server (m110 gen 10) so only 2 physical NICS
Will have first nic for host management and second nic for virtual switch
Whats best way to trunk the VLANS (there are 5 of them) to the second nic?
Thanks,
Solved! Go to solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
There are tons of documentation on https://documentation.meraki.com ...
But all depends on how your network is build. I would expect that the routing core is the MS425. With that the MX is completely out of the equation. If the Hyper-V is also attached to the Core, then the Access-switches are not relevant here. All you need to look at, are the two ports connecting to the VM-Host. Now I would think that a 10Gig-Port is a waste of ressources only for Hyper-V-Management. I would put both NICs to trunk and make sure that the VMs can use either ports which also gives you some redundancy.
If your setup is differnet, you should provide some more information here.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi TippTop,
Maybe this documentation article does help you.
Kind Regards
Niklas
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Thanks both firewall and switches are Meraki
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Practically there is only "Trunk" available for this use-case. And if you do not need any native VLAN, I would leave native VLAN on the port blank and configure the HyperV to tag all the data-vlans.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Thanks Karsten, is there any documentation on that
The Firewall is MX100
Core switch is ms425 then 10 MS225 switches
Is all this carried out on the core switch?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
As @KarstenI said, I would use both NICs for hypervisor and guests. Tag all the guest VLANs and the hypervisor connection, then on the switch ports set as trunk with no native VLAN. Alternatively an easier setup to get up and running, though a little less secure, is to leave the hypervisor untagged and set it as the native VLAN on the switch trunk ports.
