We're migrating to the Cisco Community on March 29. The Meraki Community will enter read-only mode starting on March 26.
MS supports OSPF & Static route only if MS is in routed mode,Right ?
MS can support BGP if MS is in Passthrough Mode,Right?
what is difference between routed & Passthrough Mode?
It sounds like you are talking about a MX.
i would suggest reading this document. Also note that MX only advertise ospf to the LAN and not learn routes.
BGP does works 2 way.
https://documentation.meraki.com/Architectures_and_Best_Practices/Cisco_Meraki_Best_Practice_Design/...
MX only advertise ospf to the LAN and not learn routes.then how can MX device learn about LAN subnets if it does not learn routes
You need to use static routes on the mx for that.
Just in case you really do mean MS (aka switches) - the MS250 and above support OSPF. No MS supports BGP.
