MS - Switch firmware versions MS 17.2.1.1 changelog
RaphaelL
General important notes
  • MS17 introduces a change to the default login credentials for the device local status page, using "admin" as the username, and the device serial number (upper case with dashes) as the password
  • Networks configured to run MS 17.2.1.1 will not upgrade MS22, MS42, MS220, or MS320 switches. Instead, those switches will remain on their previously configured firmware version.
Ms12x important notes
  • MS 16 introduced DAI on MS100 series platforms. If you are upgrading to a current release from MS 15 or earlier please ensure trusted ports and/or DAI-allow lists are configured prior to upgrading.
New feature highlights
  • DOM (Digital Optical Monitoring)
  • Intelligent Capture
  • RSPAN and VLAN Based SPAN
  • SmartPorts
New ms130x feature highlights
  • Adaptive Policy on MS130X/R models
New ms150 feature highlights
  • Static routing on all MS150 models
General fixed issues
  • All new LAG configurations will block redundant links if the connected device is not configured for LACP. This change fixes an issue where switches would sometimes move LAG ports to an active forwarding state prior to LACP convergence, creating the potential for loops. The change does not apply to existing LAG configurations.
  • Corrected the Local Status Page to show the 1 Gbps (forced) option, previously mislabeled as 1 Gbps (auto)
  • Fixed a bug that caused some clients using Hybrid, 802.1X, or MAB Access Policies to fail to authenticate after a switch reboot
  • Port-bounce CoA commands now correctly cycle PoE ports
  • Resolved an issue that caused some clients to be incorrectly added to a configured Guest VLAN when authenticated via RADIUS immediately after a switch reboot
  • Resolved an issue that prevented some MS210 and MS225 devices from correctly releasing MAC addresses from the MAC forwarding table
  • Resolved an issue that sometimes caused MS350 switches to remove existing L3 SVIs when enabling Auto-stacking
Ms120 fixed issues
  • Fixed a bug that prevented MS120-48 switches from correctly forwarding multicast traffic on ports 25-48
  • Resolved a bug that caused Epson POS printers to fail to authenticate when using MAB hybrid auth access policies
Ms12x fixed issues
  • Fixed an issue that prevented MS120 and MS125 switches from forwarding link-local multicast (224.0.0.x) traffic when 'Flood unknown multicast traffic' was disabled
Ms130 fixed issues
  • Fixed a bug that caused some MS130-X switches to experience slow upstream when connected directly to an MX device via an mGig port
Ms150 fixed issues
  • Resolved an issue that sometimes caused floods of unknown unicast packets when client MAC addresses migrated between physical ports
Ms225 fixed issues
  • Resolved an issue that caused some MS225-48FP devices to become unresponsive and fail to forward traffic until rebooted
Ms350 fixed issues
  • Fixed a bug that prevented cable tests from correctly functioning on mGig ports
Ms35x fixed issues
  • Resolved an issue that caused some MS350-24X and MS355 switches to fail to negotiate 802.3bt UPoE LLDP connections
Ms4xx fixed issues
  • Fixed a bug that incorrectly caused STP transitions when SFP modules were inserted/removed
General known issues
  • In rare circumstances switches may experience uplink instability when IPv6 link-local addresses are enabled. If this issue is encountered it can be resolved by enabling IPv6 RA Guard to block ICMPv6 neighbor discovery messages.
  • LACP links may take up to two minutes to come back up when the Active Member of a stack reboots
  • On MS250 and MS350 switches, MAC addresses learned via AGGR are not removed when LAG ports are disabled. Mac addresses will be removed correctly within 5 minutes of reenabling LAG ports.
  • RADIUS communications may not recover after an initial failure when Critical Auth is enabled
  • Some switches may encounter an error, "incompatible configuration for attributes: allowed_vlans" when attempting to aggregate ports regardless of allowed VLANs configured in Dashboard
Ms120 known issues
  • Switches may fail to provide PoE power to legacy access points (always present)
Ms150 known issues
  • Client MAC addresses changing physical ports may cause a flood of unknown unicast packets to the source port on MS150-48 switches
Ms220 known issues
  • Client devices connected to ports 24-48 on MS220-48LP switches may have their DHCP offers and ARP replies erroneously dropped
Ms225 known issues
  • MS225 switches may infrequently stop forwarding client traffic until the switch is rebooted
  • In rare circumstances MS225 switches may encounter a software crash that results in a reboot
Ms250 known issues
  • In rare circumstances MS250 switches using Multi-Domain Hybrid auth access policies may enter a 'port not forwarding' state, sending clients to the Guest VLAN until the switch is rebooted
Ms355 known issues
  • When reconnecting a stack cable between MS355-48X2 swithces a stack member may go offline until both switches are rebooted
Ms35x known issues
  • In rare instances, stack ports fail to initialize after an upgrade (always present)
  • Incorrect SFP port mappings may disrupt SFP functionality
  • Switches may experience an unexpected reboot (present since MS 15)
Ms410 known issues
  • Some MS410 switches may encounter alerts for fan failures that will eventually self-resolve
Ms425 known issues
  • In rare circumstances MS425 switches may encounter a software crash that results in a reboot
  • MS425s in stack configurations may periodically trigger New DHCP Server alerts that include mismatched VLANs/subnets
  • Powering off the active switch in a MS425 stack may result in up to 5 minutes of downtime while the stack reconverges
6 Replies 6
RaphaelL
The real diff between 17.2.1 and 17.2.1.1 :
Ms150 fixed issues
Ms220 known issues
Ms225 known issues
Ms410 known issues
RaphaelL
Big rant incoming.
Why MS220 known issues when these switches do not even run MS 17.2 ?
Unexpected reboots and forwarding issues on multiple models , how can this version be deemed stable at all ? I don't understand. Feels like they are rushing firmwares
This looks beta at best.
RSU21it
Completely agree.  I'm a bit confused on the fixes vs known issues listed for the 225 specifically - is the issue fixed or not???
I mostly have MS225s so I think I will sit on this for awhile and stay on the older 16.9
That is a goody!
Miroslav_Novak
Just browsing
Ms150 known issues
When will a solution be available for the MS150-48FP-4X switch? I am very disappointed. I lost a week of time looking for a hard-to-detect problem caused by the manufacturer. The investment in 8 switches in a stack has been wasted so far. For now, I had to at least connect them in a star without redundancy.
stoo
Ms130 fixed issues
  • Fixed a bug that caused some MS130 switches to fail to provide PoE when running MS 17.2.1
Seems they may have updated the changelog since it was initially posted here - the above item is now also shown on our dashboard.
I haven't checked the rest of the changelog for any differences - just spotted this one as we're dealing with some PoE quirks on an MS130.
