MS 355 Port Mirroring
Sarv
I want to Mirror ports (one-to-one), Mirror trunk port 49 to port 30, then mirror Trunk port 50 to Port 31 on the same switch, it seems that I can not do that? Is this not possible? Each time I try to mirror it forces me to use the same destination port from the previous Mirror I have setup.
Sarv
Inderdeep
@Sarv : MS switches support one-to-one or many-to-one mirror sessions.   Cross-stack port mirroring is available on  stackable switches. Only one active destination port can be configured per switch/stack.
So you can only configure one active destination port not more per switch per stack
https://documentation.meraki.com/MS/Port_and_VLAN_Configuration/Switch_Ports
Cisco Awarded Blogs 2020/2021 https://www.thenetworkdna.com/
2 Replies 2
Inderdeep
Sarv
Thank you.
