MS-355-48X2 MGIG ports
Kwisatz
I am currently chasing an issue where I have a couple MR53E AP's and they are connected to MGIG ports on my MS-355, when it first powers up it states 2500mbps/2.5G, but after about a day I see them drop back to 1000mbps/1G...Has anyone else had issues wit the MGIG ports holding the negotiation?
Total cable length from switch port to AP is 14m and 16m, respectively...I've tried different ports on the switch and swapped cables...scratching head now...
switch running 11.31 and AP's running 26.7
3 REPLIES 3
MerakiDave
Re: MS-355-48X2 MGIG ports
Hello @Kwisatz I believe there was an issue with this in MR26.6 but thought it might have been resolved in 26.6.1, but here you are on 26.7.  Likewise, I believe there was a related issue with mGig ports not correctly displaying the 1G vs 2.5G speeds, but that was in MS11.29.  I'd suggest opening a case with Meraki Support and let them triage this and determine if this might be escalated to with the MR or MS teams.  Make sure to include these data points you mentioned, especially that it's happening with multiple APs, so it's apparently not an L1 issue.
Kwisatz
Thanks Dave, I've since upgraded my switches to 12.11Beta to see if that made a difference, but alas no...I will gather all the details and open a case...Thanks!
MerakiDave
Thanks, please do report back with the findings, I checked the release notes and known issues and there is a similar known issue to be corrected in an upcoming release, but it is mentioned as being specific to MS390, doesn't mention MS355, but Support can investigate with the MS team.  Do you happen to have any other models of APs that can connect at 2.5, or you only have MR53E APs?  Just wondering if there's a way to gather any additional data points.  If not, you could work with your Meraki rep to spin up a trial of an MR46 for example also running 26.7 to see if it happens there also and further prove it may be the MS doing this.
Also, if you go to Switch > Switch Ports and turn on the "Link" column in the flex table, and then in the search box type "lldp:MR53" and just look at those switch ports that have active MR53E APs connected, you can sort and reverse sort on that Link column and export the table.  If you check back on that periodically, are the results different, do the ports tend to sometimes report 1G and other times 2.5G, or do they consistently start out at 2.5G when the AP boots, stay there for a perhaps random period of time, and then report 1G.  Wondering if once they report 1G, if they stay that way or might report back at 2.5 at any point.
In addition, wondering if it really bounced back to 1G, or if it's actually connected still at 2.5G and it's some type of cosmetic UI bug.  With that lldp:MR53 filter in place, make sure the Sent Bytes column is on, reverse sort on that to find the most heavily utilized MR53, and click into that ports details page.  Check the port traffic over the last day or week, see if you might spot any spikes that were in excess of 1G even if/when the port was reporting 1G connectivity.  That port traffic graph isn't super-granular or adjustable, might be difficult to spot.  Support might be able to dig deeper into the details to better determine if it's a cosmetic error or if the port is definitely downshifting from 2.5 to 1Gbps.  But on that note, when the port is reporting 1G, the AP itself is also reporting 1G on the AP's status page?
