Lost packets between cisco 9500 (Meraki monitoring) and Fortinet
AntoineBAK
I have core switches 9500 connected to Fortigate 600F
Fortigate owns the layer 3.
When there are just some few devices connected, all is working well
however ,with more clients around 1,000 connected, we start to lost packets and the client encountered disconnections especially towards Zscaler.
9500 version. 17.9.2
Do you saw issues in the past between 9500 and Fortinet ?
can you please help me to understand ?
Thanks,
Antoine B
Mloraditch
9500s can only be Meraki monitored so you may want to post over in the main community.cisco.com forum if you arent able to open a support case with either or both vendors.
With Full IOS-XE capabilities there could be scenarios and settings that most of us aren’t familiar with.
We can certainly try to assist if the Meraki Monitoring is offline but otherwise we may not be of much help.
6 Replies 6
Are you using GRE tunnel in the tunnel with Zscaler?
I believe the tunnel is made in the Firewall, right?
I personally understand that it is probably not a problem with the switch itself, could you share a screenshot?
Another thing, I would consider checking if there is a CPU and memory spike, either on the Firewall or on the switch when the problem is occurring.
AntoineBAK
I think we are using .pac for zscaler connections
Mloraditch
AntoineBAK
thank you so much for your support
Issue is solved
The 9500 is meraki monitored.
This action has created the tracking of all the interfaces included the interfaces towards the firewall.
The command looks likes this:
interface port-channel
device tracking attach-policy MERAKI_POLICY
With a show device-tracking messages, we can observe packet drop on the port channel between the 9500 and the fortinet
The solution is to apply this on all the interfaces especially on the ports towards the gateway
device-tracking attach-policy NOTRACK
We observe no more packet loss.
I'm not sure these tracking commands are useful for the monitoring of core switches.
Mloraditch
If you haven't involved Meraki support I suggest you do at this point, Just to make them aware. I doubt it's intended that their monitoring setup is supposed to do that.
Thanks for sharing the results!
