Location switch with coordinates
nst1
I want to add locations to my switches but my equipment is located in locations such as a hill, then the locations with co-ordinates.
for example  19°34'59.36"N,  97°18'19.75"O
but when I add it to the switch it does not accept it and try to remove the "N and" Or also separate it with a "," but it is still the same message
Enter the coordinates in "decimal" format, for example:
36.766358,-116.393507
When I have to do it, I find the location in Google Maps.  Long left click to "drop a pin".  Right click on the pin and select "What's here".  The GPS co-ordinartes appear down the bottom (from a desktop at least) in the right format for Meraki.
Now we just need "plus code" support.
1 REPLY 1
