IPV4 ACLs
BlakeRichardson
IPV4 ACLs
 We initally looked at using a MS425-32 to do all of the routing on our netwokr however when we found that you couldn't add in port ranges and only a single port as well as the low number of ACL's that can be added we had to change tact.
Does anyone know if anything has changed on this front, I don't have a spare switch to play around with this as all of our switches are currently in production.
jdsilva
This isn't a good sign 😞
@jdsilva  Thanks, I have no idea why ranges aren't supported but thats a question for the software engineers. Thanks for checking!
No problem.
When I pulled the docs for these I was reminded of another reason why using these might be more trouble than they're worth:
Sometimes if you have a very simply topology, like core MS425 switches, and then you have just a couple of links to distribution switches and the access switches hang off those you can use MX's in passthrough mode between the core and distribution layer, and have them do the firewalling.
You'd probably want to use at least MX250s to get 10Gbe ports.
https://documentation.meraki.com/MX/Networks_and_Routing/Passthrough_Mode_on_the_MX_Security_Applian...
