We are implementing a network for AV applications, like Dante audio over IP, NDI and lighting control.
Last year, we implemented the core part and 3 access switches and this year we added quite a bunch of access switches.
Before this year's extension, we had IGMP snooping enabled on the whole network and things worked fine - all multicast traffic was flowing as expected.
The following multicast groups are used for all devices to work properly:
Group address | Port | Usage |
239.255.0.0/16 | 4321 | ATP Multicast Audio |
239.69.0.0/16 | 5004 | AES67 Multicast Audio (RTP / AVP port) |
223.0.0.233 | 8700-8706 | Dante Control |
224.0.1.129-132 | 319, 320 | PTP |
224.0.0.251 | 5353 | mDNS |
224.0.0.230 – 233 | 8700 – 8708 | Multicast Control and Monitoring |
239.16x.x.x | ACN Yamaha | |
239.192.x.x-239.195.x.x | SDT session, dyn. Based on IP and MAC Shure | |
239.254.1.1 | 9998 | Logging |
239.254.3.3 | 9998 | PTP Logging (if enabled) |
239.254.44.44 | 9998 | Logging |
239.255.254.253 | 8427 | Multicast SLP Shure/Yamaha |
239.255.255.250 | 1900 | SSDP, service discovery Shure |
239.255.255.253 | SLP multicast address Shure | |
239.255.255.255 | 9875 | SAP (AES67 discovery) |
After adding the access switches this year, we have a problems with multicast traffic reaching them from other switches. Only on the NEW switches. They are all connected over a trunk LAGG to the core switches with the same admin VLAN and allow all VLANs.
So we had to limit IGMP snooping to the core switches to re-gain normal functionality. This is a problem for access points and 100Mbps devices, we can't leave the network in this situation.
Does someone know what can be a problem for multicast traffic on Meraki switches? All switches are MS425-32, MS125-24/48.
And how on earth this problem happens only on new switches?? Is there a hardware change?
Thanks,
Daniel
And there are differences, the ms120-8p models we got a couple of months ago differ from the ones we received a year or so ago as the new ones experienced the PoE mis-location issue, but the old did not...
No, 24 and 48 ports models.
IGMP snooping querier is enabled on each VLAN where needed.
