We're migrating to the Cisco Community on March 29. The Meraki Community will enter read-only mode starting on March 26.
I looked at the spec sheets on the MS-250 switches and while it says that they support IGMP snooping (by default I believe), it does not specify which version. Is IGMP Snooping v3 supported?
Solved! Go to solution.
All MS should support v3 (and hence v2). This doc mentions the RFC it adheres to.
@Yves_Richarz : Check if it helps
https://documentation.meraki.com/MS/Layer_3_Switching/MS_Multicast_Routing_Overview
Thank you. I read that doc and it is informative, but does not specifically mention v3.
Thank You!
