How to view transciever levels from the Meraki Dashboard
Scott5
I am trying to troubleshoot a fiber issue I am seeing with my MS120-48LP switch and another switch I have in another building connected via multimode fiber. I am not seeing any way to check transceiver levels from the Meraki Dashboard.
Ryan_Miles
Meraki Employee All-Star
Nothing in the dashboard. You might try opening a Support case. But I don't think the any MS model (except MS390) has the capability even by Support.
BlakeRichardson
@Scott5 Also if the transceivers are not Meraki branded support might not offer any help.
You should use the "Make a wish" feature for this.  It would be really helpful when trying to diagnose a fault.
Even if the "cable test" tool (which doesn't normally work) was updated to be able the check the levels for being "normal" would be a good start.
