- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
How to remove CDP/LLDP information from port
Hello. I'm new to Meraki. just wondering how can I remove the CDP/LLDP information from the port status section. I am no longer connecting a cisco switch to that port. I just want that CDP info to go away since it's not up to date anymore. Thank you.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
How long ago was that switch removed? I believe it'll refresh in time. There is a way to force the refresh as well. I'm trying to dig up that information from an old ticket.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Looks like the old ticket I had involved a Meraki AP not reporting CDP correctly to the switch. We just toggled the CDP off then back on via the AP. So not quite the same issue you are having. If it doesn't clear in a few days I'd recommend double checking that it isn't somehow still detecting an upstream device. Especially using that little raw link in your screenshot.
Alternatively, you could try bouncing the port to see if that helps clear the CDP/LLDP identification.
