We're migrating to the Cisco Community on March 29. The Meraki Community will enter read-only mode starting on March 27.
I try to configure MS-120 to authorize with 802.1x.
So, I want to know how to bulk import user to Meraki authentication.
I can see register one by one but can't see bulk import operation.
https://documentation.meraki.com/zGeneral_Administration/Cross-Platform_Content/Managing_User_Accoun...
In 2017, there were no way.
https://community.meraki.com/t5/Dashboard-Administration/Meraki-Authentication-bulk-user-creation/m-...
Solved! Go to solution.
Thank you for your reply.
I understood it.
I accidentally marked my post....😣
**EDIT**
Removing my comment. I was totally wrong and @ww called me out on it 🙂
There is no way to bulk import users. The meraki user system is only intended for managing small groups of users.
A larger solution should be using RADIUS.
