- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
How to create layer 3 interfaces on MS?
Solved! Go to solution.
- Labels:
Layer 3
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
On a compatible device such as a MS320-24 switch you can find the Layer 3 Routing tab under Switch > Monitor > Switches > Your Selected Compatible Switch then on the header tab the 4th tab has an L3 Routing option. This feature will however need to be enabled under Switch > Configure > Routing and DHCP > Then adding an Interface to route to/from. I've included screenshots of these sections.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Do you have a supported model for Layer 3? Check this page:
https://documentation.meraki.com/MS/Layer_3_Switching/MS_Layer_3_Switching_Overview
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Thanks, this worked for me!
