Hi all,
I´ve an urgent question regarding your experiences with the following scenario...
I noticed that 2 switch ports on the meraki switch are on the opposite side configured for a LACP LAG - the correct configuration should be a LAG but how should I fix that? regarding the official documentation the links should be connected after the Aggregation has been configured in dashboard, but that`s unfortunatley now not possible anymore?!
maybe someone has an experience and can tell me if it can also work with active ports?
thanks for any response
