Solved! Go to Solution.
Yes, you need a router/security device in the middle. An MX series device would be a good choice.
You can choose a model from this page that is suitable based on the number of users that you have.
https://meraki.cisco.com/products/appliances#models
It may also be possible to pay for service provider an extra fee and have them put in a managed firewall/router for you.
Are they all going to be used in the same VLAN? Is this for guest WiFi? Are you also using an MX to connect to the Internet? If so, I would run DHCP off the MX appliance.
Thank you Philip for your reply, i have this scenario: my isp provides me with one unique public IP and no DHCP they say me their device doesn't support DHCP so i can connect one only device directly to internet forcing me to install a router or in this case the Meraki MS350-24X. I have configured a DHCP server on vlan 10 on the MS350 and a interface with the public ip like gateway, trying to use it like a bridge between both networks but i get the MR84 connected on the MS350's DHCP Pool but they can´t reach the internet so i need help with this configuration, can you help me with this? tahnk you again. and best regards.
Did you make sure to set up a route to the public? Should be something along the lines of:
Subnet: 0.0.0.0/0
Next hop IP: Public IP address
This is a printscreen of the MS350-24X:
the first interface is to get the switch into the subnet of the isp modem with the ip 192.168.1.3
the second is the dhcp pool i created to conect the MR84 as dhcp clients of the switch
the third is the static route to the internal isp modem ip. (here i should change it for the external ip instead the internal?).
this is the config i tried but with no success.
thank you in advance and excuse me for my poor english.
Does the ISP do NAT for you? It sounds like the answer is no. If not then you need a device that can do NAT, like an MX65. Choose an MX from this page that is big enough to support the number of users you have.
Thank you for your reply Philips, and the answer is no, my isp is not doing NAT, its means that i need a Router in the mittle, don,t you?
A MX device in the middle would definitely help you out!
