Getting frustrated VLAN Setup
BSD54
I have an MS425 that I am trying to get up and running with VLAN.  When I create two VLANS I can ping from one to the other but I can't ping the out side world.  I am trying to get it ready to replace an old Catalyst 3550.  What should the uplink port on the switch be set to?  When I look at the uplink port on the 3550 it is set to an access port but doesn't state what VLAN it is on.
Thanks,
Adam
11 Replies 11
Do you have a default route created?
https://documentation.meraki.com/MS/Layer_3_Switching/MS_Layer_3_Switching_and_Routing
Here is an example.
.https://documentation.meraki.com/MS/Layer_3_Switching/Layer_3_Switch_Example
One more.
https://documentation.meraki.com/MS/Layer_3_Switching/Comparing_Layer_3_and_Layer_2_Switches
https://www.certificationkits.com/cisco-certification/ccna-articles/cisco-ccna-intro-to-routing-basi....
Brash
I think maybe a small topology and the Catalyst config for the port facing the MS425 would be beneficial.
If the port config is set for access with no "switch port access vlan <x>" command, it will use the default vlan (by default vlan 1).
Ryan_Miles
Is the 3550 maybe using a L3 routed port config? Meraki switches don't support routed ports today and instead you'd define a L3 interface on the switch and then place the switch port into said VLAN.
When you created the first VLAN on the MS425 it would have required a next hop IP which would in turn create a default route out from the switch. Is that next hop reachable? And, does the next hop know how to get back to the Meraki switch VLAN(s)?
What is acting as the default gateway in these VLANs - the MS425?  If so, does your firewall have a route for the new VLANs via the MS425?
BSD54
I just had it plugged into our network through a trunk port.  I created a couple of vlans on it just to play around but when a port is on those vlans it can't get to the out side world.  If I have a port set to a vlan that already exists in my network then it works fine.
BSD54
Where I am getting confused is can I just plug it into a trunk port in my network and get it up and running.
Man you need a default route, it's a basic thing about network and routing.
Just to clarify, it's because you are creating a L3 VLAN, because of that you need to create a default route. I sent you a few links to read, you just need to trust us.
