Flexible Stacking Over Aggregated Links
KiloBravo
I have two MS425 switches that I'd like to stack; these switches will be used for servers and connect directly to the core (a pair of stacked MS450 switches).
The MS425 have 2 x 40G QSFP+ interfaces for stacking *or* uplinking, no dedicated stacking ports at the rear (according to documentation) and 32 x 10G SFP+ fiber. This gives me two options:
  1. Stack the switches using the 40G stack/uplink ports. Then use multiple 10G interfaces, aggregated and connected up to the core, can go up to 8 interfaces if I've read correctly.
  2. LAG the 2 x 40G interfaces and connect up to the core, giving me 80G uplinks. Then Use the 10G interfaces to stack the switches.
My question is, with option 2, am I limited to 2 x 10G interfaces to stack with? or can i aggregate multiple interfaces on each switch and then use the aggregate's as stack links?
Thanks in advance.
2 REPLIES 2
BrechtSchamp
Unfortunately stacked ports cannot be aggregated
2019-06-27 12_00_05-Clipboard.pngd.
Thanks for confirming. Looks like I'll be using the 2x40G  for up-links and 2x10G for flexible stacking then.
