Hi @Richard-Tapp,
Brash and cmr pretty much covered it! This Product End-of-Life (EOL) Policy page is another great reference 🙂
A product's EOL (End-of-Life) and EOST (End-of-Support) date are basically equivalents and reference the same date. When the device reaches EOL/EOST, the product's lifetime warranty period also ends (if it's a product covered by a lifetime warranty, which MS switches are.) Additionally, the device is no longer affirmatively supported by Cisco Meraki (please still feel free to open a Meraki Technical Support case on these devices if needed, but please be aware that this support will be on a best case effort basis and not guaranteed.)
After the EOL/ EOST date, the changes that may occur will include the following:
- Cisco Meraki cannot guarantee that legacy hardware products will be able to connect to the management software indefinitely following the EOST Date;
- Cisco Meraki Technical Support may no longer troubleshoot the legacy hardware products;
- Cisco Meraki may no longer issue firmware updates or patches for the legacy products; and
- New software features available for the management software may not be compatible with the legacy hardware functionality or with the firmware running on the legacy hardware.
Best,
Feli
If you found this post helpful, please give it kudos. If this answer helped solve the issue, click "accept as solution" so that others can benefit from it.
