802.1x Wired connection with EAP-TLS authentication
Dror
Just browsing
Hi all,
so after a long time I was finally able to authenticate devices via Access policy in Meraki MS225 +NPS server in order to authenticate computers with Domain Computers group and certificate. But the thing is,its working only with 'Smart Card or other certificate (EAP-TLS)' authentication method, and I also had to change some more inner additional settings.
The default NIC configuration is EAP(PEAP), and it's not working with this method.
Now, if I want to apply the policy for all computers, it doesn't make sense that I need to go each computer and set it manually..
How can I change the NIC configurations for all computer organizations? Couldnt see something like this in GPO.
Thanks in advance,
Dror
6 Replies 6
KH
Meraki Employee All-Star
This question is likely better suited for the vendor of your client machines, Typically would be pushed via GPO however if you don't see one you might have to implement a PowerShell script or similar and push it to all the devices that way.
If you found this post helpful, please give it kudos. If my answer solved your problem, click "accept as solution" so that others can benefit from it
Maybe it will help you: https://learn.microsoft.com/en-us/previous-versions/windows/it-pro/windows-server-2012-r2-and-2012/...
Dror
Just browsing
thanks but the link seems to be broken
Try it again please.
Dror
Just browsing
Man, you made my day! thats exactly what ive needed.
I could edit and deploy the Wired network policies from GPO for all computers. works after reboot,
Thanks!!
A couple of tips.
You need a group policy for workstations to do two things:
* Enabled the Wired AutoConfig service
* Configure the authentication to match what you are using in NPS.
You wont be able to get it to work without setting the above two.
