DHCP / routing with template binding
Fabian1
Hi everyone,
I'm wondering where I can find the option DHCP and Routing after binding a network to a template. I can't find it under the template configuration and network switch configuration.
I might be just blind and I'm sure you guys can help me.
Best regards
Fabian
MerakiDave
Meraki Employee All-Star
Unfortunately MS configuration templates only work with L2 deployments today, so that's why you're not seeing the "Routing and DHCP" configuration option when the switches are bound to a template.
https://documentation.meraki.com/MS/Deployment_Guides/Switch_Templates_Deployment_Guide_(CVD)
What kind of device is being used?  MX?  MS?
MerakiDave
jcottage
