Is this question about converting a Catalyst switch to Meraki or just recreating a similar config on a Meraki switch that you have or had on a Catalyst switch?
If it's the latter then it's important to understand the key difference with a cloud managed Meraki switch vs. a Catalyst or other non cloud managed switch. A Meraki switch requires a management IP to communicate with dashboard. Think of it like a simple client with a unique IP that talks to dashboard. This mgmt IP can be on a native or tagged VLAN.
A Meraki switch can also have layer 3 IPs for local VLANs if it's performing routing or DHCP relay functions. Layer 2 VLANs don't require any special config on a Meraki switch like a VLAN database or anything. A trunk port on a Meraki switch assumes it can carry any VLAN 1-4094.
Ryan / Meraki SE
If you found this post helpful, please give it Kudos. If my answer solved your problem click Accept as Solution so others can benefit from it.
