Connecting Dell Server to Cisco Meraki MS425
jfitz0715
I am setting 10 Dell PowerEdge Server to my Meraki MS 425 Switch.  The Dell server use to ports (DHCP, iDRAC).  One of the ports will get a DHCP Address from the switch.  However, the other port will need a static address to allow our system admin to access iDRAC.
Is it possible to have a static port with an address and how would I set it up?  Just food for thought, I will need to setup 10 static address for 10 dell servers.
Thanks in advance for the information.
~ Jerry
I'm guessing you mean static IP addresses.  You can configure a static IP address as you would normally.  There is nothing special to be done.
GIdenJoe
It's not really clear what you mean with static ports.
Usually you have access ports towards your management like iDRAC, iLo, CIMC and simple trunk ports towards your actual VMNIC's allowing all VLAN's that you need for your VM's to run on.
If you mean you need a subnet where the MS425 is the gateway you can have DHCP and or fixed IP addresses for sure.
Please clarify your idea further, perhaps even with a drawing.
jfitz0715
Thanks PhilipDAth.
