Configuring Role on cisco 1300 ports
Configuration
Hello Team ,
  As part of AAA authentication how /where should we configure a role sothat  authenticated user will be assigned with specific role.
I believe you are talking about TACACS authentication, which does not apply to the Meraki dashboard.
Correct me if I am wrong. In any case, here is a guide on how to configure authentication via CLI.
Configure Change of Authorization in Catalyst 1300 Using Web User Interface - Cisco
Cisco Catalyst 1300 Switches Series CLI Guide - AAA Commands [Cisco Catalyst 1300 Series Switches] -...
Configuration
Can you please tell me how do we configure the role with Meraki MS250 switch ?
Role for what function exactly? 802.1x authentication on ports? What Radius server do you have? Cisco ISE, Freeradius, Mricosoft NPS?
Some useful links.
https://documentation.meraki.com/MS/Access_Control/MS_Switch_Access_Policies_%28802.1X%29
https://community.cisco.com/t5/security-knowledge-base/how-to-integrate-meraki-networks-with-ise/ta-...
