Clone Switch Settings From Cisco 4500 switches to Meraki MS425-32
Riser
Does anyone know if we can clone settings from the Cisco 4500 switch to the Meraki MS425-32? We are looking at making the change and trying to find an easier way through this.
GIdenJoe
Those are two radically different platforms.  You may not even support the same features as you are using now in your new design.
In this case I think you should just list all the configurations that are relevant in your new design and are supported on the MS425 and just do the config.  I assume that won't be that much of a work.
2 Replies 2
GIdenJoe
DarrenOC
I’m sure somebody will pipe up stating write a Python script etc but honestly the graft will be better spent exporting your 4500  Config and map ports and Config to your new MS
