We're migrating to the Cisco Community on March 29. The Meraki Community will enter read-only mode starting on March 26.
After updating our switches to MS 16.8/ CS 16.8. When we search for the client details, it does not show any accurate information. Is this a bug?
I would suggest you open a support case.
I open a case and they instruct me to go to Switching>switching setting then check Exclude uplink interfaces (default)
It that was the only change - there is a good chance it is a bug.
You could also try resetting the client tracking data. Change the client tracking option, click save, and then change it straight back.
https://documentation.meraki.com/MX/Monitoring_and_Reporting/Client-Tracking_Options
Thanks i will check on this.
What switches do you have and what is not correct?
