Cisco Meraki HTTP Proxy Process Question
aboyd
Greetings All,
Does anybody have any references or documentation on the process to build a proxy server to be used for the HTTP Proxy functionality within the Meraki MS switches?  I'm getting the runaround internally from a number of people saying that we need to setup a Web Proxy in Server 2016, which requires AD FS, which we won't be utilizing.
To give some context, here's our situation.
A lot of our Meraki switches sit in a controlled environment.  Rather than opening up the firewall for the switches to communicate with the Meraki Cloud, we want to utilize a Proxy in our internal DMZ for the switches to communicate with the Meraki Cloud.
I'm having a difficult time figuring out how to achieve this task and would appreciate any guidance or suggestions.
Thank you
1 REPLY 1
Don't use Windows.  Too hard.
Use a free proxy like squid on Ubuntu.
http://www.squid-cache.org/
It is built into the Ubuntu repositories.
I also found these walk though instructions.  Don't be surprised if you finish 10 minutes after you start once Ubuntu is installed.  It's pretty simple.  It is also very reliable.
https://tecadmin.net/setup-squid-proxy-server-on-ubuntu/
If you are a sadist and really want to use Windows for this - I think you can get squid for Windows.
