Cisco 891F-K9 & MS130-8X
Shadius
Hi all,
I recently received a Cisco 891F-K9 router and an MS130-8X switch. I'd like to set them up to use for a home lab to start learning.
I have Verizon as my ISP.
How would I set these up?
I'm assuming the Cisco 891F-K9 router will plug into one of the LAN ports on the Verizon router for Internet access.
Any help is appreciated!
2 Replies 2
Here you can find the basic configuration.
https://community.cisco.com/t5/switching/configuring-the-891f-router-for-internet-lan-to-wan-access/...
I have a Config Wizard that will do 90% (maybe even 100%) of the config for you.  You can find it here:
https://www.ifm.net.nz/cookbooks/890-isr-wizard.html
Note that "UFB" means "fibre".
