Changing the VLAN on stack switches
AnkitSharma1
Hi Expert,
We have three floors. We are using two switches on each floor, and now we have added one more switches on each floor, and all the new switches are added to a stack. I see all the new switch ports showing under management VLAN 1
How can I isolate MGT traffic and move all the ports from VLAN 1 to another master switch VLAN?
I don't understand your question, are you referring to the configuration of the switches' physical ports or the switch's management VLAN?
It got a little confusing.
https://documentation.meraki.com/MS/Other_Topics/Switch_Settings#Management_VLAN
Check it out.
https://documentation.meraki.com/MS/Port_and_VLAN_Configuration/Configuring_Multiple_Switch_Ports_on...
Go to the Switches/Switch ports view, click on all the ports you want to change and change them to access mode and a different VLAN as below:
