Catalyst Meraki Monitoring Stack Failover Issues
Brash
I'm setting up a Catalyst 9500 stack with Meraki monitoring and have noticed a strange issue:
Whenever I perform a failover (power pull or CLI) to the second switch in the stack, it is never able to connect to the Meraki dashboard. The TLS Tunnel always shows down and the switch shows offline in the dashboard.
As soon as I switch back to switch 1, the tunnel is re-established, the Meraki user logs in and the device comes back online in the Meraki dashboard.
Has anyone else encountered this behaviour?
I'm planning to raise it with support but am working through some other issues first related to unexpected crashes seemingly caused by the Meraki TLS Tunnel.
5 Replies 5
Firmware up to date on the 9500 stack?
Brash
Running the 'Cisco recommended' (starred release) 17.6.4.
Tried an upgrade to 17.6.5 as well.
Catalyst licensing up to date and activated?
Brash
Licensing is DNA Advantage and is activated and we'll in date.
I actually dug a bit further on this and it turns out that there's a few different issues occurring.
On failover, the tunnel does actually establish within a minute or so, but it takes ~20 minutes for the status to true up in the dashboard. In the meantime, if another failover occurs, the tunnel then fails to come up and will sometimes crash the switch.
I've got cases open with both Cisco TAC and Meraki so hoping we'll be able to get it sorted. Just interested to see if anyone else using the feature has seen similar.
Hughes_S
Hey Brash, I know this is an old issue for you, but I am currently having the same problem.. What was your resolution?  My design is 3x failover circuits 2x learned over OSPF and the 3rd is a floating  default route with a AD of 254. However, when failing over any circuit, my tunnel does not appear to re-establish. Thanks again for your help and insight.
