Cannot Reset MS355 (frm16.5) to factory default
ZubJoh
Cannot Reset MS355 (frm16.5) to factory default. press and hold reset button. Switch reboot but configuration stays.
Not much we can do, if you pressed it long enough, thats about it.
Contact meraki support .
Is this switch linked to a network?
If so, you have to remove it from the network before doing the factory reset.
ZubJoh
The switch is completely offline with no cable connected. I have tried with another switch configured the same way and it works.
