Can send SNMP Trap to snmp server?
Qing
Hi, is it possible to send snmp traps to snmp server from meraki device? We want to automatically receive the alert from meraki network . The snmp server is at remote site. Please advise, thanks in advance.
No, this is what the email alerts, APIs and webhooks are for.  There is SNMP support but only for queries.
4 REPLIES 4
Qing
Thanks for your reply.
GreenMan
Actually, you can send SNMP traps from a Meraki solution - but it has to be enabled by Support:   https://documentation.meraki.com/zGeneral_Administration/Monitoring_and_Reporting/SNMP_Overview_and_...
Note that the traps come from the Meraki Dashboard, not the devices themselves hence the Receiving server IP must be a public IP  (think: security - SNMPv3..?)
Given this, @cmr 's recommendation to look at other alerting mechanisms still bears consideration.
Actually, thinking about it a bit more, I'm not sure the other proactive alerting mechanisms are any more secure (certainly not compared to properly implemented SNMPv3)
