Cable testing on ports
How well/accurate is the cable testing on the Meraki switches? Just looking for opinions on how they have helped. Does it accurately measure cable distance, when you find failures does it happen again when using a different cable, or how often do you notice a cable failure?
kYutobi🌝
3 REPLIES 3
Re: Cable testing on ports
It's rare I have a faulty ethernet cable but I just so happened to have one 2 weeks ago
I was transferring about 25GB to my Synology NAS at home, and I noticed it was unusually slow. Peaking at 10MB/s (100Mbps) so I checked the NIC on the Synology OS and sure enough, showing 100Mbps.
Swapped the cable and it went to 1Gbps, much faster.
So I took that cable thinking 'could this really be bad?' and plugged it into my MS120 and MR33 and within 5 minutes I got an email alert about a faulty cable. So it seems to work to me 😃
Nolan Herring | nolanwifi.com
TwitterLinkedIn
It's been pretty accurate for us. We identified problems with nearly a dozen brand new cables that someone had run through the walls, thanks to the cable test function.
Friends don't let friends hire people who don't regularly run cable.
I have had mixed results, Cable length not always accurate for me.
