Cable lenght
AnnaSew
Just browsing
Cable lenght
I doing a cables-lenght test in meraki. Cabels from switch to hosts are 43- 50 long, but in Meraki i see 90-100 meters. Anybody know why? How is this length calculated than it is 2 x longer?
9 Replies 9
The cable length is determined using TDR (Time Domain Reflectometry):
https://en.wikipedia.org/wiki/Time-domain_reflectometer
It measures the time for a signal to be reflected due to tiny imperfections in the cable termination.  The signal travells at a constant speed, so the length can be calculated.
Accuracy of Cable Test with MS - The Meraki Community
AnnaSew
Just browsing
Reflectometer "tells" me 43 meters, but Meraki 100 meters.Could be a bug in Meraki?
I suggest you open a support case to confirm.
DarrenOC
Hi @AnnaSew , I would personally get an external company in to check those cable runs.  Sounds like they’ve been incorrectly terminated.
AnnaSew
Just browsing
External companys are responsibility for that.
DarrenOC
Hi @AnnaSew and what are their testers showing?  Have they stuck a Fluke at both ends of the cable?
AnnaSew
Just browsing
43-50 meters, and Meraki 90-100 meters
To be quite honest, I trust Fluke 1000 times more than the Meraki test. I see the Meraki test more as a quick fix, so I wouldn't get too attached to it.
If in doubt, I would do as I said, open a support case.
What switch model and what firmware are you running?  There was a recent bug with MS130s reporting double the length...
