C9300X-NM-8M Network module compatible with Meraki C9300X?
SimonReach
Looking on the C9300X-M datasheet site on the Meraki website, it lists the optional accessories at the bottom of the page.  The Cisco page lists more items, in particular the C9300X-NM-8M, which isn't listed on the Meraki page, is every module on the Cisco page also compatible with the Meraki firmware?
Catalyst 9300X-M Datasheet - Cisco Meraki Documentation
Cisco Catalyst 9300 Series Switches Data Sheet - Cisco
I'm asking as it'll be plugging into an MX85 and ideally wanted to stick with 10GbE rather than SFP+ or SFP28 and optical cabling.
If not, i'll ask the Meraki support to clarify.
SimonReach
Meraki support have replied back with the below so will be using ports 23/24 as the uplink ports to the primary and warm spare MX85 devices, saves some expense on our part anyway.
As of now, the 'C9300X-NM-8M' does not officially support on C9300X-M switch
As stated in the following document, only the 'C9300X-NM-2C-M' and 'C9300X-NM-8Y-M' are currently supported.
[Catalyst 9300X-M Datasheet - Cisco Meraki Documentation]
https://documentation.meraki.com/MS/MS_Overview_and_Specifications/Catalyst_9300X-M_Datasheet
5 Replies 5
I noticed that the 10GBaseT SFP is not listed as supported either.
I am slightly confused - the MX85 has no 10Gbe ports, so why can't you use a plain Gigabit copper port?
SimonReach
The plan was to get the 1GbE/10GbE module and use that as an uplink to a 1GbE port on the MX device.  An alternative is to not use a module at all and just use port 24 on the switch to a port on the MX device but it uses a port that might be required in the future.
I'd buy the 8 port SFP+ module and a GLC-TE transceiver in that case, or just use port 24...
GIdenJoe
Yes I also found it strange that the multigig modules did not get a -M variant.
SimonReach
