While it's a C9300 Cisco switch, and the supported SFP matrix from Cisco, says yes, I'd still rely on what the Meraki Datasheet says. This is to ensure support from Meraki, just in case.
The C9300X-24Y-M datasheet says that it supports 10G twinax.
https://documentation.meraki.com/MS/MS_Overview_and_Specifications/Catalyst_9300X-M_Datasheet
If possible, I'd go with the Meraki SKU, so ensure compatibility and support.
	LinkedIn :::
https://blog.rhbirkelund.dk/Like what you see? - Give a Kudo ## Did it answer your question? - Mark it as a Solution
🙂All code examples are provided as is. Responsibility for Code execution lies solely your own.
